Ir para o conteúdo principal
Amazon Kindle 8 Front Cover Replacement
O que você precisa
  1. Amazon Kindle 8 Front Cover Replacement, Front Cover: passo 1, imagem 1 %32 Amazon Kindle 8 Front Cover Replacement, Front Cover: passo 1, imagem 2 %32
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Front Cover Replacement: passo 2, imagem 1 %32 Amazon Kindle 8 Front Cover Replacement: passo 2, imagem 2 %32
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Luke
Membro desde: 09/25/24
420 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 317
