Ir para o conteúdo principal
Amazon Fire TV Stick Remote Battery Replacement
O que você precisa
  1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: passo 1, imagem 1 %32 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: passo 1, imagem 2 %32 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: passo 1, imagem 3 %32
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
    Pergunte ao FixBot
    Comentar
  2. Amazon Fire TV Stick Remote Battery Replacement: passo 2, imagem 1 %32
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Andrew Busse
Membro desde: 07/12/16
933 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-3, Harley SU 2016 Membro de IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Membros
Autoria de 15 guias
35Comentários do guia
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Responder Compartilhar
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber - Responder Compartilhar
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Responder Compartilhar
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 76
Últimos 30 dias: 181
Ao todo: 122,208
