Ir para o conteúdo principal
Amazon Fire HD 8 12th Gen Camera Replacement
O que você precisa
  1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, imagem 1 %32 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, imagem 2 %32 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, imagem 3 %32
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
    Pergunte ao FixBot
    Comentar
  2. Amazon Fire HD 8 12th Gen Camera Replacement: passo 2, imagem 1 %32 Amazon Fire HD 8 12th Gen Camera Replacement: passo 2, imagem 2 %32
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
    Pergunte ao FixBot
    Comentar
  3. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: passo 3, imagem 1 %32 Amazon Fire HD 8 12th Gen Camera Replacement, Camera: passo 3, imagem 2 %32
    • Using the iFixit opening tool, disconnect the battery from the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, imagem 1 %32 Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, imagem 2 %32 Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, imagem 3 %32
    • Disconnect the camera from the motherboard by unplugging the orange wiring.
    • Heat the area of the back camera up loosening the glue holding it in place.
    • Be careful when using hot tools and removing hot parts.
    Pergunte ao FixBot
    Comentar
  5. Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, imagem 1 %32 Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, imagem 2 %32 Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 383
