Ir para o conteúdo principal
Amazon Fire HD 8 12th Gen Button Replacement
O que você precisa
    1. Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, imagem 1 %32 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, imagem 2 %32 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, imagem 3 %32
      • Remove the device from any electrical source and make sure it is powered off.
      • Put picks around the corner and move them along the edge to pry the case off.
      • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
      Pergunte ao FixBot
      Comentar
    2. Amazon Fire HD 8 12th Gen Button Replacement: passo 2, imagem 1 %32 Amazon Fire HD 8 12th Gen Button Replacement: passo 2, imagem 2 %32
      • With the corners lifted, take the opening tool and pry each corner off.
      • Repeat this for the corner diagonal from the initial corner.
      • Once both corners are pried off, gently take the back case off the device.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 67
Ao todo: 661
