Ir para o conteúdo principal
Amazon Fire HD 10 Rear Facing Camera Replacement
O que você precisa
    1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, imagem 2 %32 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: passo 1, imagem 3 %32
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Pergunte ao FixBot
      Comentar
    2. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 2, imagem 1 %32
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Pergunte ao FixBot
      Comentar
    3. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 3, imagem 1 %32 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 3, imagem 2 %32
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 4, imagem 1 %32
      • Remove the screen and digitizer from the case completely.
      Pergunte ao FixBot
      Comentar
    1. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: passo 5, imagem 1 %32 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: passo 5, imagem 2 %32
      • Remove the single T5 Torx screw at the base of the camera.
      • Once removed, place the screw aside in a safe location.
      Pergunte ao FixBot
      Comentar
    2. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 6, imagem 1 %32 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 6, imagem 2 %32
      • Lift the camera from the case using the plastic opening tool.
      • The camera is still connected to the motherboard via the ZIF connector.
      Pergunte ao FixBot
      Comentar
    3. Amazon Fire HD 10 Rear Facing Camera Replacement: passo 7, imagem 1 %32 Amazon Fire HD 10 Rear Facing Camera Replacement: passo 7, imagem 2 %32
      • Gently grab the camera and pull to remove.
      • The camera is now free from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Jaie Hillery
Membro desde: 10/07/14
1.774 Reputação
Autoria de 10 guias
Equipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro de USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Membros
Autoria de 80 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 44
Ao todo: 1,271
