Ir para o conteúdo principal
Amazon Fire Game Controller Outer Shell Replacement
O que você precisa
  1. Amazon Fire Game Controller Outer Shell Replacement, Motherboard: passo 1, imagem 1 %32
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
    Pergunte ao FixBot
    Comentar
  2. Amazon Fire Game Controller Outer Shell Replacement: passo 2, imagem 1 %32
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
    Pergunte ao FixBot
    Comentar
  3. Amazon Fire Game Controller Outer Shell Replacement: passo 3, imagem 1 %32
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Amazon Fire Game Controller Outer Shell Replacement: passo 4, imagem 1 %32
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Amazon Fire Game Controller Outer Shell Replacement: passo 5, imagem 1 %32
    • Lift the motherboard out of the controller casing.
    Pergunte ao FixBot
    Comentar
  6. Amazon Fire Game Controller Outer Shell Replacement, Outer Shell: passo 6, imagem 1 %32
    • Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
    Pergunte ao FixBot
    Comentar
  7. Amazon Fire Game Controller Outer Shell Replacement: passo 7, imagem 1 %32
    • Use a JIS #0 screwdriver to unscrew the 5 mm screws from the LED indicator assembly.
    Pergunte ao FixBot
    Comentar
  8. Amazon Fire Game Controller Outer Shell Replacement: passo 8, imagem 1 %32 Amazon Fire Game Controller Outer Shell Replacement: passo 8, imagem 2 %32
    • Slide out the triggers and bumpers.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team S4-G4, Wilson Summer 2019 Membro de IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 840
