Ir para o conteúdo principal
Amazon Fire 5th Generation Speaker Replacement
O que você precisa
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: passo 1, imagem 1 %32 Amazon Fire 5th Generation Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
  2. Amazon Fire 5th Generation Speaker Replacement: passo 2, imagem 1 %32 Amazon Fire 5th Generation Speaker Replacement: passo 2, imagem 2 %32
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
  3. Amazon Fire 5th Generation Speaker Replacement: passo 3, imagem 1 %32 Amazon Fire 5th Generation Speaker Replacement: passo 3, imagem 2 %32 Amazon Fire 5th Generation Speaker Replacement: passo 3, imagem 3 %32
Conclusão
Uma outra pessoa concluiu este guia.
Amber Bunch
Membro desde: 02/10/16
1.391 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-2, Nance Spring 2016 Membro de USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 1,379
