Introdução
Use this guide to replace the rear-facing camera of the Amazon Fire 5th Generation.
Peças
Nenhum componente especificado.
While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
Then, remove the back cover from the device.
The battery connector is located in the upper left corner of the Amazon Fire battery pack.
To disconnect the battery connector, use angled ESD precision tweezers to lift the cables up and out of their socket.
The LCD Digitizer on the Amazon Fire tablet has a locking cable connector that holds it in place on the motherboard.
To remove the cable, use the iFixit Opening Tool to unlock the LCD Digitizer cable connector.
Once the wire connector is removed, use the iFixit Opening Tool to pry the entire LCD Digitizer away from the motherboard.
The rear facing camera is directly attached with adhesive to the device case.
In order to remove the camera, use a plastic opening tool to wedge underneath and lift it out of its place.
Uma outra pessoa concluiu este guia.
