Introdução
Use this replacement guide if the microphone of the Amazon Echo Show 8 is not functioning. The microphone is important when it comes to being able to use the “Alexa” commands as well as video calling. Before continuing with this replacement guide, go to the troubleshooting guide and ensure you have completed the trouble shooting steps. This guide will walk you through replacing the microphone. Make sure the device is disconnected from the power before proceeding with the guide.
O que você precisa
Flip the device so that the rubber foot is facing up.
Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
Remove the rubber foot.
Orient the Echo with the microphone board facing upwards.
Use a spudger to gently remove the 2 pieces of foam covering the ribbon cables.
