Ir para o conteúdo principal
Amazon Echo Show 8 2nd Generation Camera Replacement
O que você precisa
  1. Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: passo 1, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: passo 1, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: passo 1, imagem 3 %32
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 2, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 2, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 2, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 3, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 3, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 3, imagem 3 %32
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 4, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 4, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 4, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: passo 5, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: passo 5, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: passo 5, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the screen assembly.
    • There is a screw that is not pictured in the center of the bottom two screws.
  6. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 6, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 6, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 6, imagem 3 %32
    • Gently separate the speaker housing from the display assembly and set the device on a flat surface.
    • There is a cable connecting the speaker housing to the display assembly. Take care not to pull on it while separating the two parts.
    • Use a plastic spudger to pry up and remove the foam mat at the center of the silver bracket.
  7. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 7, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 7, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the eleven 6 mm screws that secure the silver bracket.
  8. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 8, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 8, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 8, imagem 3 %32
    • Use a plastic spudger to lift up the remove the silver bracket.
    • The camera is located to the left of the mother board.
  9. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 9, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 9, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 9, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the two 6 mm screws that secure the camera retention plate.
  10. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 10, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 10, imagem 2 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 10, imagem 3 %32
    • Use a spudger to slightly lift the camera retention plate.
    • Lift the camera retention plate up and out of the chassis.
  11. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 11, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 11, imagem 2 %32
    • Use the pointed end of a spudger to flip up the camera ribbon cable ZIF locking flap.
    • Pull the ribbon cable directly out of its socket.
  12. Amazon Echo Show 8 2nd Generation Camera Replacement: passo 12, imagem 1 %32 Amazon Echo Show 8 2nd Generation Camera Replacement: passo 12, imagem 2 %32
    • Lift up the camera gently, and use the pointed end of the spudger to gently remove the thin black ribbon cable.
    • The thin tab holding is held down with adhesive. Be gentle when removing it to prevent tearing it.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 534
