Introdução
The Amazon Echo Look's primary function as a fashion assistance can be affected if the front panel is cracked or if the lens is smudged on the inside or otherwise damaged.
Some steps are time-sensitive and may need to be repeated- the time estimate reflects this.
O que você precisa
Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
Uma outra pessoa concluiu este guia.
