Ir para o conteúdo principal
Aluratek ADMPF310F Speakers Replacement
O que você precisa
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: passo 1, imagem 1 %32 Aluratek ADMPF310F Speakers Replacement, Speakers: passo 1, imagem 2 %32 Aluratek ADMPF310F Speakers Replacement, Speakers: passo 1, imagem 3 %32
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: passo 2, imagem 1 %32
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: passo 3, imagem 1 %32 Aluratek ADMPF310F Speakers Replacement: passo 3, imagem 2 %32
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: passo 4, imagem 1 %32 Aluratek ADMPF310F Speakers Replacement: passo 4, imagem 2 %32
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: passo 5, imagem 1 %32
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
Conclusão
Chris Belair
Membro desde: 10/20/16
333 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 107
