Ir para o conteúdo principal
Aluratek ADMPF310F Replacing USB Port Replacement
O que você precisa
  1. Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: passo 1, imagem 1 %32 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: passo 1, imagem 2 %32 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: passo 1, imagem 3 %32
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Replacing USB Port Replacement: passo 2, imagem 1 %32
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Replacing USB Port Replacement: passo 3, imagem 1 %32 Aluratek ADMPF310F Replacing USB Port Replacement: passo 3, imagem 2 %32
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Replacing USB Port Replacement: passo 4, imagem 1 %32
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Replacing USB Port Replacement: passo 5, imagem 1 %32
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Replacing USB Port Replacement: passo 6, imagem 1 %32 Aluratek ADMPF310F Replacing USB Port Replacement: passo 6, imagem 2 %32
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Replacing USB Port Replacement: passo 7, imagem 1 %32 Aluratek ADMPF310F Replacing USB Port Replacement: passo 7, imagem 2 %32 Aluratek ADMPF310F Replacing USB Port Replacement: passo 7, imagem 3 %32
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Replacing USB Port Replacement: passo 8, imagem 1 %32
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
  9. Aluratek ADMPF310F Replacing USB Port Replacement, USB Port: passo 9, imagem 1 %32
    • On the back end of the mother board unsolder the USB port at the two points shown.
Conclusão
Pascal Alexis
Membro desde: 11/05/15
427 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 144
