Ir para o conteúdo principal
Aluratek ADMPF310F Remote Sensor Replacement
O que você precisa
  1. Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, imagem 1 %32 Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, imagem 2 %32 Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, imagem 3 %32
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Remote Sensor Replacement: passo 2, imagem 1 %32
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Remote Sensor Replacement: passo 3, imagem 1 %32 Aluratek ADMPF310F Remote Sensor Replacement: passo 3, imagem 2 %32
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Remote Sensor Replacement: passo 4, imagem 1 %32
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Remote Sensor Replacement, Remote Sensor: passo 5, imagem 1 %32
    • Pull out the remote sensor from its holder with your hands.
    • Unsolder the remote sensor from the motherboard.
  6. Aluratek ADMPF310F Remote Sensor Replacement: passo 6, imagem 1 %32
    • Resolder the the remote sensor back to the motherboard.
    • For more on how to solder check the link here.
Conclusão
Pascal Alexis
Membro desde: 11/05/15
427 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 391
