Introdução
If your Altec Lansing Mini Lifejacket 2's speaker is damaged or faulty, use the following step-by-step guide to replace it. This guide applies to both the speakers.
O que você precisa
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
To remove the back panel, gently pull out its wire harness.
conclusion????? what i do now????
Remove the rubber ring from the rim of the speaker.
Uma outra pessoa concluiu este guia.
2 comentários
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
Where can I get this speaker parts?
