Ir para o conteúdo principal
Altec Lansing Mini Lifejacket 2 Speaker Replacement
O que você precisa
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 2, imagem 3 %32
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 3, imagem 2 %32
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 4, imagem 3 %32
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 5, imagem 2 %32
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 6, imagem 2 %32
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 7, imagem 1 %32
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 8, imagem 1 %32
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 9, imagem 3 %32
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: passo 10, imagem 2 %32
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 2 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 11, imagem 3 %32
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, imagem 1 %32 Altec Lansing Mini Lifejacket 2 Speaker Replacement: passo 12, imagem 2 %32
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Stephen Albrecht
Membro desde: 02/14/18
1.029 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G2, Nance Spring 2018 Membro de USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
Membros da 4
Autoria de 4 guias
2 comentários
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Responder
Where can I get this speaker parts?
T Rex movies - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 31
Duração total: 4,016
