Ir para o conteúdo principal
Altec Lansing BoomJacket Bluetooth Board Replacement
O que você precisa
  1. Altec Lansing BoomJacket Bluetooth Board Replacement, Case Removal: passo 1, imagem 1 %32
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 2, imagem 1 %32
    • Remove the outer black rubber housing of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 3, imagem 1 %32
    • Remove the inner blue rubber housing from the speaker.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 4, imagem 1 %32
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 5, imagem 1 %32 Altec Lansing BoomJacket Bluetooth Board Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 6, imagem 1 %32
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 7, imagem 1 %32
    • Pull the case apart and you will be able to see all the components inside the speaker.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing BoomJacket Bluetooth Board Replacement, Bluetooth Board: passo 8, imagem 1 %32
    • Now that the case is open look for the small green (NFC) chip on the inside of the case next to the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing BoomJacket Bluetooth Board Replacement: passo 9, imagem 1 %32
    • Disconnect the Bluetooth (NFC) chip from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Is this a common issue with the Lifejacket 3? I was able to use my new BT speaker twice, since it was bought last week. The speaker hasn't been dropped, in or around water, outside, left on, damaged, or tampered with.
Kat - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 5,139
