Ir para o conteúdo principal
Altec Lansing BoomJacket Battery Replacement
O que você precisa
  1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: passo 1, imagem 1 %32
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing BoomJacket Battery  Replacement: passo 2, imagem 1 %32
    • Remove the outer black rubber housing of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing BoomJacket Battery  Replacement: passo 3, imagem 1 %32
    • Remove the inner blue rubber housing from the speaker.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing BoomJacket Battery  Replacement: passo 4, imagem 1 %32
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing BoomJacket Battery  Replacement: passo 5, imagem 1 %32 Altec Lansing BoomJacket Battery  Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing BoomJacket Battery  Replacement: passo 6, imagem 1 %32
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing BoomJacket Battery  Replacement: passo 7, imagem 1 %32
    • Pull the case apart and you will be able to see all the components inside the speaker.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing BoomJacket Battery  Replacement, Battery: passo 8, imagem 1 %32
    • The battery will be sitting right behind the speakers when the case is open.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing BoomJacket Battery  Replacement: passo 9, imagem 1 %32
    • Unplug and disconnect the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
6Comentários do guia
Where can you buy a replacement battery?
Darrell riley - Responder Compartilhar
Where can you buy the battery please?
Juan Roa - Responder Compartilhar
Where can I find ghe batteries? What type of battery ?
Violet Roach - Responder Compartilhar
where ca i buy a replacement battery
Shelley Franck - Responder Compartilhar
This tutorial is incomplete.
Ivan Rodriguez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 15,912
