Ir para o conteúdo principal
Altec Lansing BoomJacket 2 Motherboard Replacement
O que você precisa
  1. Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 1 %32 Altec Lansing BoomJacket 2 Motherboard Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 2 %32
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
    Pergunte ao FixBot
    Comentar
  2. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 2, imagem 1 %32 Altec Lansing BoomJacket 2 Motherboard Replacement: passo 2, imagem 2 %32
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
    Pergunte ao FixBot
    Comentar
  3. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 3, imagem 1 %32
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
    Pergunte ao FixBot
    Comentar
  4. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 4, imagem 1 %32 Altec Lansing BoomJacket 2 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
    Pergunte ao FixBot
    Comentar
  5. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
    Pergunte ao FixBot
    Comentar
  6. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 6, imagem 1 %32
    • Gently pull apart the front panel from the base of the speaker.
    Pergunte ao FixBot
    Comentar
  7. Altec Lansing BoomJacket 2 Motherboard Replacement, Battery: passo 7, imagem 1 %32
    • The battery will be in the middle of the speaker when the case is open.
    Pergunte ao FixBot
    Comentar
  8. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 8, imagem 1 %32
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
    Pergunte ao FixBot
    Comentar
  9. Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Altec Lansing BoomJacket 2 Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Disconnect the furthest right hand plug first.
    • Do not pull from the wires. Pull from the white connector.
    Pergunte ao FixBot
    Comentar
  10. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 10, imagem 1 %32
    • Gently pull the motherboard directly upwards to avoid damage.
    • Be sure to lift slowly.
    Pergunte ao FixBot
    Comentar
  11. Altec Lansing BoomJacket 2 Motherboard Replacement: passo 11, imagem 1 %32
    • Disconnect the remaining connectors from the motherboard.
    • Do not forcefully pull connectors. Pull from the connectors, not from the wires.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Zach Braaten
Membro desde: 07/12/18
537 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Membros
Autoria de 4 guias
1Comentário do guia
Where is the best place to purchase a motherboard for the Altec Lansing Jacket H20 4?
Kelvin Jasper - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 1,211
