Introdução
Electrolytic capacitors are electronic components used to store energy. If too much current runs through a capacitor, it may become bulged and need to be replaced. To replace a capacitor on the MRV-M500 you will need previous experience soldering electronics. To learn how to solder, see this guide.
O que você precisa
Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
3 outras pessoas executaram este guia.
