Ir para o conteúdo principal
AlphaSmart Pro Lithium Coin Battery Replacement
O que você precisa
    1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 2 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, imagem 3 %32
      • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      Pergunte ao FixBot
      Comentar
    2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, imagem 2 %32
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      Pergunte ao FixBot
      Comentar
    3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, imagem 2 %32
      • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
      Pergunte ao FixBot
      Comentar
    4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, imagem 1 %32 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, imagem 2 %32
      • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
      • Slide the battery out from underneath the clip that holds it in place.
      • The positive side of the battery is facing up.
      Pergunte ao FixBot
      Comentar
Conclusão
Katy Beth Culp
Membro desde: 10/13/14
1 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-1, Benson Fall 2014 Membro de Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 58
Ao todo: 1,459
