Ir para o conteúdo principal
AlphaSmart Pro Front Panel Replacement
O que você precisa
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, imagem 1 %32 AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, imagem 2 %32 AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, imagem 3 %32
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    Pergunte ao FixBot
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: passo 2, imagem 1 %32 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: passo 2, imagem 2 %32
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
    Pergunte ao FixBot
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, imagem 1 %32 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, imagem 2 %32 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, imagem 3 %32
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
    Pergunte ao FixBot
Conclusão
Nathan Smith
Membro desde: 10/13/14
22 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-1, Benson Fall 2014 Membro de Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 52
Ao todo: 539
