Ir para o conteúdo principal
Alldaymall A88X Speaker Replacement
O que você precisa
  1. Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: passo 1, imagem 1 %32 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: passo 1, imagem 2 %32 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: passo 1, imagem 3 %32
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Speaker Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Speaker Replacement, Speaker: passo 3, imagem 1 %32 Alldaymall A88X Speaker Replacement, Speaker: passo 3, imagem 2 %32 Alldaymall A88X Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Speaker Replacement: passo 4, imagem 1 %32 Alldaymall A88X Speaker Replacement: passo 4, imagem 2 %32 Alldaymall A88X Speaker Replacement: passo 4, imagem 3 %32
    Comprar
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Speaker Replacement: passo 5, imagem 1 %32 Alldaymall A88X Speaker Replacement: passo 5, imagem 2 %32 Alldaymall A88X Speaker Replacement: passo 5, imagem 3 %32
    • Desolder the speaker wires from the motherboard.
Conclusão
Drhaber
Membro desde: 02/10/16
985 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 4-1, Lacy Spring 2016 Membro de USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 230
