Ir para o conteúdo principal
Alienware m15 R6 Memory module Replacement
O que você precisa
    1. Alienware m15 R6 Memory module Replacement, Base Cover: passo 1, imagem 1 %32
      • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
      • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
      • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
      Pergunte ao FixBot
      Comentar
    2. Alienware m15 R6 Memory module Replacement: passo 2, imagem 1 %32
      • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
      • Lift the base cover off the palm-rest and keyboard assembly.
      Pergunte ao FixBot
      Comentar
    3. Alienware m15 R6 Memory module Replacement: passo 3, imagem 1 %32
      • Disconnect the battery cable from the system board.
      • Turn your computer over and press the power button for 20 seconds to drain the flea power
      Pergunte ao FixBot
      Comentar
    1. Alienware m15 R6 Memory module Replacement, Memory module: passo 4, imagem 1 %32
      • Lift the system board Mylar to access the memory module.
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory modulepops up.
      • Remove the memory module from the memory-module slot.
      Pergunte ao FixBot
      Comentar
Conclusão
Andrzej
Membro desde: 02/17/23
1.732 Reputação
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 466
