Ir para o conteúdo principal
Alienware X51 RAM Replacement
O que você precisa
    1. Alienware X51 RAM Replacement, Front Panel: passo 1, imagem 1 %32
      • Place the PC so the name "Alienware" is on top and facing you.
      • Slide the front panel towards you and lift up.
      Pergunte ao FixBot
      Comentar
    2. Alienware X51 RAM Replacement: passo 2, imagem 1 %32
      • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
      • Remove the front panel from the rest of the device.
      Pergunte ao FixBot
      Comentar
    1. Alienware X51 RAM Replacement, Fan: passo 3, imagem 1 %32 Alienware X51 RAM Replacement, Fan: passo 3, imagem 2 %32
      • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
      • Remove the protector holding the fan in.
      Pergunte ao FixBot
      Comentar
    2. Alienware X51 RAM Replacement: passo 4, imagem 1 %32
      • Disconnect the Molex KK connector from the fan.
      Pergunte ao FixBot
      Comentar
    3. Alienware X51 RAM Replacement: passo 5, imagem 1 %32 Alienware X51 RAM Replacement: passo 5, imagem 2 %32 Alienware X51 RAM Replacement: passo 5, imagem 3 %32
      • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
      • Gently pull back the clips and remove the fan by pulling it out.
      Pergunte ao FixBot
      Comentar
    1. Alienware X51 RAM Replacement, Disc Drive: passo 6, imagem 1 %32 Alienware X51 RAM Replacement, Disc Drive: passo 6, imagem 2 %32
      • Disconnect the optical-drive data and power cable.
      Pergunte ao FixBot
      Comentar
    2. Alienware X51 RAM Replacement: passo 7, imagem 1 %32
      • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
      • Remove the disc drive from the PC.
      Pergunte ao FixBot
      Comentar
    1. Alienware X51 RAM Replacement, RAM: passo 8, imagem 1 %32 Alienware X51 RAM Replacement, RAM: passo 8, imagem 2 %32 Alienware X51 RAM Replacement, RAM: passo 8, imagem 3 %32
      • Pull apart the clips that hold the RAM sticks in place.
      • Remove the RAM sticks.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 558
