Ir para o conteúdo principal
Alienware Pro Wireless Gaming Mouse Motherboard Replacement
O que você precisa
  1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: passo 1, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: passo 1, imagem 2 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: passo 1, imagem 3 %32
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
    Pergunte ao FixBot
    Comentar
  2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 2, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 2, imagem 2 %32
    • Peel and remove the other mouse foot.
    Pergunte ao FixBot
    Comentar
  3. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
    Pergunte ao FixBot
    Comentar
  4. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 4, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 4, imagem 2 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 4, imagem 3 %32
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
    Pergunte ao FixBot
    Comentar
  5. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 5, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 5, imagem 2 %32
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
    Pergunte ao FixBot
    Comentar
  6. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 6, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 6, imagem 2 %32
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  7. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: passo 7, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: passo 7, imagem 2 %32
    • Pinch the upper part of the ribbon cable.
    • Pull the ribbon cable gently to detach it from the socket on the motherboard.
    • Make sure the ribbon line is facing the correct direction when reassembling the controller.
    Pergunte ao FixBot
    Comentar
  8. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 8, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the side button panel from the plastic frame.
    Pergunte ao FixBot
    Comentar
  9. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: passo 9, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: passo 9, imagem 2 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: passo 9, imagem 3 %32
    • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
    • Only light force is needed—be gentle to avoid damaging nearby parts.
    Pergunte ao FixBot
    Comentar
  10. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 11, imagem 1 %32
    • Gently pull the side clip away from the motherboard to release it from the plastic frame.
    • Use a spudger to release the board from the clips if that is easier.
    Pergunte ao FixBot
    Comentar
  12. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 12, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: passo 12, imagem 2 %32
    • Bend the front nose of the mouse body to release the motherboard.
    • Remove the motherboard from the bottom case.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Matt Seay
Membro desde: 09/29/25
401 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 181
