Ir para o conteúdo principal
Alienware Pro Wireless Gaming Mouse Battery Replacement
O que você precisa
  1. Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: passo 1, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: passo 1, imagem 2 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: passo 1, imagem 3 %32
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
    Pergunte ao FixBot
    Comentar
  2. Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 2, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 2, imagem 2 %32
    • Peel and remove the other mouse foot.
    Pergunte ao FixBot
    Comentar
  3. Alienware Pro Wireless Gaming Mouse Battery Replacement, Battery: passo 3, imagem 1 %32
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
    Pergunte ao FixBot
    Comentar
  4. Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 4, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 4, imagem 2 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 4, imagem 3 %32
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
    Pergunte ao FixBot
    Comentar
  5. Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 5, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 5, imagem 2 %32
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
    Pergunte ao FixBot
    Comentar
  6. Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 6, imagem 1 %32 Alienware Pro Wireless Gaming Mouse Battery Replacement: passo 6, imagem 2 %32
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Matt Seay
Membro desde: 09/29/25
401 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 254
