Ir para o conteúdo principal
Alienware M18x Internal Fan Replacement
O que você precisa
    1. Alienware M18x Internal Fan Replacement, Internal Fan: passo 1, imagem 1 %32 Alienware M18x Internal Fan Replacement, Internal Fan: passo 1, imagem 2 %32 Alienware M18x Internal Fan Replacement, Internal Fan: passo 1, imagem 3 %32
      • Turn the computer over.
      • Slide the battery latch over and lift the battery out.
      Pergunte ao FixBot
      Comentar
    2. Alienware M18x Internal Fan Replacement: passo 2, imagem 1 %32
      • Unscrew the four indicated screws with a J000 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Alienware M18x Internal Fan Replacement: passo 3, imagem 1 %32 Alienware M18x Internal Fan Replacement: passo 3, imagem 2 %32
      • Use the plastic pryer tool to lift the bottom cover off.
      Pergunte ao FixBot
      Comentar
    4. Alienware M18x Internal Fan Replacement: passo 4, imagem 1 %32 Alienware M18x Internal Fan Replacement: passo 4, imagem 2 %32
      • With the back cover removed, locate the desired fan to replace.
      Pergunte ao FixBot
      Comentar
    5. Alienware M18x Internal Fan Replacement: passo 5, imagem 1 %32 Alienware M18x Internal Fan Replacement: passo 5, imagem 2 %32 Alienware M18x Internal Fan Replacement: passo 5, imagem 3 %32
      • Use a J000 screwdriver to loosen the screws that secure the fan(s).
      • There are three internal fans within the laptop. Locate the correct screws to loosen for the desired fan to replace based on the provided corresponding images.
      Pergunte ao FixBot
      Comentar
    6. Alienware M18x Internal Fan Replacement: passo 6, imagem 1 %32 Alienware M18x Internal Fan Replacement: passo 6, imagem 2 %32 Alienware M18x Internal Fan Replacement: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      • The fan will be connected to the motherboard by a cable. Use plastic tweezers to gently unplug this connection.
      Pergunte ao FixBot
      Comentar
    7. Alienware M18x Internal Fan Replacement: passo 7, imagem 1 %32 Alienware M18x Internal Fan Replacement: passo 7, imagem 2 %32
      • The fan is now fully disconnected from the computer. Gently remove the fan by lifting upwards.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team S21-G1, Banghart Winter 2018 Membro de Cal Poly, Team S21-G1, Banghart Winter 2018
CPSU-BANGHART-W18S21G1
3 Membros
Autoria de 40 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 38
Ao todo: 971
