Ir para o conteúdo principal
Alienware M17x RAM Replacement
O que você precisa
  1. Alienware M17x RAM Replacement, Battery: passo 1, imagem 1 %32 Alienware M17x RAM Replacement, Battery: passo 1, imagem 2 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Alienware M17x RAM Replacement: passo 2, imagem 1 %32
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
  3. Alienware M17x RAM Replacement: passo 3, imagem 1 %32
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
  4. Alienware M17x RAM Replacement: passo 4, imagem 1 %32 Alienware M17x RAM Replacement: passo 4, imagem 2 %32
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
  5. Alienware M17x RAM Replacement, RAM: passo 5, imagem 1 %32 Alienware M17x RAM Replacement, RAM: passo 5, imagem 2 %32
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
  6. Alienware M17x RAM Replacement: passo 6, imagem 1 %32 Alienware M17x RAM Replacement: passo 6, imagem 2 %32
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
  7. Alienware M17x RAM Replacement: passo 7, imagem 1 %32
    • Remove the bottom RAM card in a similar manner.
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 53
Ao todo: 766
