Ir para o conteúdo principal
Alienware M17x Motherboard Replacement
O que você precisa
    1. Alienware M17x Motherboard Replacement, Battery: passo 1, imagem 1 %32 Alienware M17x Motherboard Replacement, Battery: passo 1, imagem 2 %32
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17x Motherboard Replacement: passo 2, imagem 1 %32
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17x Motherboard Replacement: passo 3, imagem 1 %32
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Pergunte ao FixBot
      Comentar
    4. Alienware M17x Motherboard Replacement: passo 4, imagem 1 %32 Alienware M17x Motherboard Replacement: passo 4, imagem 2 %32
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Pergunte ao FixBot
      Comentar
    1. Alienware M17x Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
      • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
      • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
      • Twelve 5.5 mm Phillips #0 main frame screws.
      • Six 3.5 mm Phillips #0 fan screws.
      • Four 3.5 mm Phillips #0 internal compartment screws.
      • Eight 3.5 mm Phillips #0 Hard Drive screws.
      • Four 3.5 mm Phillips #0 CD Drive screws.
      • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17x Motherboard Replacement: passo 6, imagem 1 %32 Alienware M17x Motherboard Replacement: passo 6, imagem 2 %32 Alienware M17x Motherboard Replacement: passo 6, imagem 3 %32
      • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
      • Use a plastic opening tool to pry the keyboard from the base of the computer.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17x Motherboard Replacement: passo 7, imagem 1 %32
      • Remove five 3.5 mm Phillips #0 screws from the motherboard.
      • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
      • Lift the motherboard at an angle and remove it from the computer base.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 2,494
