Ir para o conteúdo principal
Alienware M17x Display Assembly Replacement
O que você precisa
    1. Alienware M17x Display Assembly Replacement, Battery: passo 1, imagem 1 %32 Alienware M17x Display Assembly Replacement, Battery: passo 1, imagem 2 %32
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17x Display Assembly Replacement: passo 2, imagem 1 %32
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17x Display Assembly Replacement: passo 3, imagem 1 %32
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Pergunte ao FixBot
      Comentar
    4. Alienware M17x Display Assembly Replacement: passo 4, imagem 1 %32 Alienware M17x Display Assembly Replacement: passo 4, imagem 2 %32
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Pergunte ao FixBot
      Comentar
    1. Alienware M17x Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32
      • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17x Display Assembly Replacement: passo 6, imagem 1 %32 Alienware M17x Display Assembly Replacement: passo 6, imagem 2 %32 Alienware M17x Display Assembly Replacement: passo 6, imagem 3 %32
      • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
      • Use the spudger to remove the siding from the bottom of the frame near the hinges.
      • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17x Display Assembly Replacement: passo 7, imagem 1 %32 Alienware M17x Display Assembly Replacement: passo 7, imagem 2 %32
      • Use the plastic opening tool to disconnect the screen from the top mount.
      Pergunte ao FixBot
      Comentar
    4. Alienware M17x Display Assembly Replacement: passo 8, imagem 1 %32
      • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
      Pergunte ao FixBot
      Comentar
    5. Alienware M17x Display Assembly Replacement: passo 9, imagem 1 %32
      • Tilt the screen forward to expose the connecting wires.
      • Disconnect said wires to then lift the display assembly out of the frame.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 1,032
