Ir para o conteúdo principal
Alienware M17-R1 Screen Lock Assembly Replacement
O que você precisa
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: passo 1, imagem 1 %32
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
  2. Alienware M17-R1 Screen Lock Assembly Replacement: passo 2, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 2, imagem 2 %32
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
  3. Alienware M17-R1 Screen Lock Assembly Replacement: passo 3, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 3, imagem 2 %32
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
  4. Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 2 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 4, imagem 3 %32
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  5. Alienware M17-R1 Screen Lock Assembly Replacement: passo 5, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 5, imagem 2 %32
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
  6. Alienware M17-R1 Screen Lock Assembly Replacement: passo 6, imagem 1 %32 Alienware M17-R1 Screen Lock Assembly Replacement: passo 6, imagem 2 %32
    • If the spring is defective, slide it off the end of the assembly and replace it.
Conclusão
William Davis
Membro desde: 10/09/18
323 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 628
