Ir para o conteúdo principal
Alienware M17-R1 Hard Drive Replacement
O que você precisa
    1. Alienware M17-R1 Hard Drive  Replacement, Battery: passo 1, imagem 1 %32
      • Push the slider until the battery is released from its socket.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17-R1 Hard Drive  Replacement: passo 2, imagem 1 %32
      • Lift the battery using your fingers.
      • It may be necessary to use a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Alienware M17-R1 Hard Drive  Replacement, Hard Drive: passo 3, imagem 1 %32
      • Place the laptop face down on a hard, flat surface to have a clear view of the bottom of the computer.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17-R1 Hard Drive  Replacement: passo 4, imagem 1 %32
      • Once you have located the hard drive, you will then need to remove the 3 mm screw using the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17-R1 Hard Drive  Replacement: passo 5, imagem 1 %32
      • Gently slide the hard drive away from the computer using the built in ridges.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
LXA054
Membro desde: 10/09/18
337 Reputação
Autoria de 3 guias
Equipe
2Comentários do guia
where can I get the two hdd doors
Rebecca Anne Guidroz - Responder Compartilhar
Hello I guess I got lucky running across this site my 2200 dollar laptop has been a brick paper weight since Mr Gates dropped support of Vista leaving a lot of non savvy pc techs hanging no where to turn prayfully this fix it site can breath new life into my Alienwares gaming mr17 r1 hard drive once more blowing dust off ("cough") as I write this help me please .
Mike Hogan Sr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 1,137
