Ir para o conteúdo principal
Alienware M17-R1 CPU Cooler Replacement
O que você precisa
    1. Alienware M17-R1 CPU Cooler Replacement, Battery: passo 1, imagem 1 %32
      • Push the slider until the battery is released from its socket.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17-R1 CPU Cooler Replacement: passo 2, imagem 1 %32
      • Lift the battery using your fingers.
      • It may be necessary to use a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Alienware M17-R1 CPU Cooler Replacement, CPU Cooler: passo 3, imagem 1 %32
      • First begin by placing the laptop on a hard flat surface.
      • Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Alienware M17-R1 CPU Cooler Replacement: passo 4, imagem 1 %32
      • Once the cover has been removed, locate the CPU Cooler to begin the replacement.
      Pergunte ao FixBot
      Comentar
    3. Alienware M17-R1 CPU Cooler Replacement: passo 5, imagem 1 %32
      • Remove the six 7 mm screws using a Phillips #1 and then use the pry tool to unplug the fan before removing the CPU Cooler.
      • Screws 1 through 4 are integrated into the cooler and will come all the way out.
      Pergunte ao FixBot
      Comentar
    4. Alienware M17-R1 CPU Cooler Replacement: passo 6, imagem 1 %32
      • Once all screws have been removed and the cooler has been unplugged, gently lift the cooler out of its compartment to install the new cooling fan.
      Pergunte ao FixBot
      Comentar
Conclusão
LXA054
Membro desde: 10/09/18
337 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 1,159
