Ir para o conteúdo principal
Alienware M15x GPU Replacement
O que você precisa
    1. Alienware M15x GPU Replacement, GPU: passo 1, imagem 1 %32
      • Turn the laptop over so that the bottom is facing upward.
      Pergunte ao FixBot
      Comentar
    2. Alienware M15x GPU Replacement: passo 2, imagem 1 %32
      • Release the battery latch and flip the battery out.
      Pergunte ao FixBot
      Comentar
    3. Alienware M15x GPU Replacement: passo 3, imagem 1 %32 Alienware M15x GPU Replacement: passo 3, imagem 2 %32
      • Remove the two 4mm screws using a Phillips #1 screwdriver.
      • Remove the compartment door by sliding it away from the battery.
      Pergunte ao FixBot
      Comentar
    4. Alienware M15x GPU Replacement: passo 4, imagem 1 %32
      • Remove the four 4mm screws with the Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Alienware M15x GPU Replacement: passo 5, imagem 1 %32
      • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
      • The laptop position should resemble an upside-down V shape.
      • Locate the panel and pry open using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    6. Alienware M15x GPU Replacement: passo 6, imagem 1 %32 Alienware M15x GPU Replacement: passo 6, imagem 2 %32 Alienware M15x GPU Replacement: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
      • Lift the power button panel using the plastic opening tool.
      • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
      Pergunte ao FixBot
      Comentar
    7. Alienware M15x GPU Replacement: passo 7, imagem 1 %32
      • Remove the two 4mm screws with a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    8. Alienware M15x GPU Replacement: passo 8, imagem 1 %32 Alienware M15x GPU Replacement: passo 8, imagem 2 %32
      • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
      • Remove the exhaust port cover entirely.
      Pergunte ao FixBot
      Comentar
    9. Alienware M15x GPU Replacement: passo 9, imagem 1 %32 Alienware M15x GPU Replacement: passo 9, imagem 2 %32 Alienware M15x GPU Replacement: passo 9, imagem 3 %32
      • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
      Pergunte ao FixBot
      Comentar
    10. Alienware M15x GPU Replacement: passo 10, imagem 1 %32
      • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    11. Alienware M15x GPU Replacement: passo 11, imagem 1 %32
      • Use a Phillips #0 screwdriver to remove the two screws.
      • Remove the GPU from the laptop.
      • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
      Pergunte ao FixBot
      Comentar
Conclusão
Tomas Kronmark
Membro desde: 01/22/18
193 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G3, Banghart Winter 2018 Membro de Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 2,331
