Ir para o conteúdo principal
Alienware M14xR2 Optical Drive Replacement
O que você precisa
  1. Alienware M14xR2 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    Pergunte ao FixBot
    Comentar
  2. Alienware M14xR2 Optical Drive Replacement: passo 2, imagem 1 %32 Alienware M14xR2 Optical Drive Replacement: passo 2, imagem 2 %32 Alienware M14xR2 Optical Drive Replacement: passo 2, imagem 3 %32
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    Pergunte ao FixBot
    Comentar
  3. Alienware M14xR2 Optical Drive Replacement: passo 3, imagem 1 %32
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    Pergunte ao FixBot
    Comentar
  4. Alienware M14xR2 Optical Drive Replacement: passo 4, imagem 1 %32 Alienware M14xR2 Optical Drive Replacement: passo 4, imagem 2 %32 Alienware M14xR2 Optical Drive Replacement: passo 4, imagem 3 %32
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    Pergunte ao FixBot
    Comentar
  5. Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, imagem 1 %32 Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, imagem 2 %32 Alienware M14xR2 Optical Drive Replacement, Optical Drive: passo 5, imagem 3 %32
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jordan Ramsey
Membro desde: 09/30/13
402 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-4, Forte Fall 2013 Membro de Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 37
Ao todo: 3,227
