Ir para o conteúdo principal
Alienware M11x Memory Module Replacement
O que você precisa
  1. Alienware M11x Memory Module Replacement, Introduction: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    Pergunte ao FixBot
    Comentar
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 2, imagem 1 %32
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Pergunte ao FixBot
    Comentar
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, imagem 1 %32 Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, imagem 2 %32
    • Remove the memory module from the memory module connector.
    Pergunte ao FixBot
    Comentar
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: passo 4, imagem 1 %32
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
    Pergunte ao FixBot
    Comentar
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: passo 5, imagem 1 %32
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
45 Membros
Autoria de 2.003 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Ao todo: 765
