Introdução
If your Alienware Aurora (M9700) doesn’t have a clear screen— unclear, cracked or dimmed— use this guide to replace the main screen. A ++faulty screen++ has several large problems such as cracked screen, leaking screen, dead pixels, or anything that impairs the function of the laptop. Double-check that your screen is not altered or dimmed based on the settings provided on your laptop.
Before beginning this guide, ensure that if your screen is cracked there are no fragments or glass that are in the way and potentially hurting to you. Make sure that all the tools required to fix the display are in your reach. Have a small cup or container to hold the screws that are removed from the product, as you will need all the screws to reinstall the new display. Make sure you are working in an Electrostatic discharge (ESD) control. Remove the battery and disconnect the laptop from the power supply, to prevent any electrical discharge.
O que você precisa
Remove the main outer screws from the back portion of the laptop.
Remove the battery from the back.
Open the laptop facing towards you.
On the right side where the power button is located, place the spudger to pry open the center panel as you slide it to the left.
Close the laptop and face the back portion towards you.
Between the green frame and the black panel insert the spudger to pry open the center panel. (Do this for both sides of the computer.)
Uma outra pessoa concluiu este guia.
