Ir para o conteúdo principal
Alcatel Pop 4 Plus Headphone Jack Replacement
O que você precisa
  1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: passo 1, imagem 3 %32
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 2, imagem 2 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 2, imagem 3 %32
    • Remove seventeen 1.2mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 3, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 3, imagem 2 %32
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 4, imagem 2 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 4, imagem 3 %32
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 5, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 5, imagem 2 %32
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 6, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 6, imagem 2 %32
    • Disconnect the phone's ribbon cable from the mother board.
  7. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 7, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon cable that binds the two motherboards together.
  8. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 8, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 8, imagem 2 %32
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 9, imagem 1 %32
    • Insert a flat tool at the edge of the phone and gently lift to remove the motherboard.
  10. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 10, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 10, imagem 2 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 10, imagem 3 %32
    • Locate the phone's headphone jack on the motherboard.
  11. Alcatel Pop 4 Plus Headphone Jack Replacement: passo 11, imagem 1 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 11, imagem 2 %32 Alcatel Pop 4 Plus Headphone Jack Replacement: passo 11, imagem 3 %32
Conclusão
Garett Marler
Membro desde: 09/19/19
202 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 176
