Ir para o conteúdo principal
Alcatel One Touch Pop 7 Rear Camera Replacement
O que você precisa
  1. Alcatel One Touch Pop 7 Rear Camera Replacement, Volume Button Assembly: passo 1, imagem 1 %32
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
    Pergunte ao FixBot
    Comentar
  2. Alcatel One Touch Pop 7 Rear Camera Replacement: passo 2, imagem 1 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 2, imagem 2 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
    Pergunte ao FixBot
    Comentar
  3. Alcatel One Touch Pop 7 Rear Camera Replacement: passo 3, imagem 1 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 3, imagem 2 %32
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
    Pergunte ao FixBot
    Comentar
  4. Alcatel One Touch Pop 7 Rear Camera Replacement: passo 4, imagem 1 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 4, imagem 2 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 4, imagem 3 %32
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
    Pergunte ao FixBot
    Comentar
  5. Alcatel One Touch Pop 7 Rear Camera Replacement, Rear Camera: passo 5, imagem 1 %32 Alcatel One Touch Pop 7 Rear Camera Replacement, Rear Camera: passo 5, imagem 2 %32
    • The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
    Pergunte ao FixBot
    Comentar
  6. Alcatel One Touch Pop 7 Rear Camera Replacement: passo 6, imagem 1 %32 Alcatel One Touch Pop 7 Rear Camera Replacement: passo 6, imagem 2 %32
    • Pull the actual camera piece from the camera slot. It may stick a bit but it shouldn't be too difficult.
    Pergunte ao FixBot
    Comentar
Conclusão
Riley Cooper
Membro desde: 10/10/16
926 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 1,073
