Ir para o conteúdo principal
Alcatel One Touch Pop 7 Display Assembly Replacement
O que você precisa
  1. Alcatel One Touch Pop 7 Display Assembly Replacement, Volume Button Assembly: passo 1, imagem 1 %32
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
    Pergunte ao FixBot
    Comentar
  2. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 2, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 2, imagem 2 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
    Pergunte ao FixBot
    Comentar
  3. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 3, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 3, imagem 2 %32
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
    Pergunte ao FixBot
    Comentar
  4. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 4, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 4, imagem 2 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 4, imagem 3 %32
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
    Pergunte ao FixBot
    Comentar
  5. Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: passo 5, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: passo 5, imagem 2 %32
    • The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
    Pergunte ao FixBot
    Comentar
  6. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 6, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 6, imagem 2 %32
    • Pull the actual camera piece from the camera slot. It may stick a bit but it shouldn't be too difficult.
    Pergunte ao FixBot
    Comentar
  7. Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: passo 7, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: passo 7, imagem 2 %32 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: passo 7, imagem 3 %32
    • We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
    Pergunte ao FixBot
    Comentar
  8. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 8, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 8, imagem 2 %32
    • Disconnect the ribbon cable and move it out of the way of the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 9, imagem 1 %32
    • Using a PH00 screwdriver to remove these seven 2mm screws and place them in a safe spot where you won't lose them.
    Pergunte ao FixBot
    Comentar
  10. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 10, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 10, imagem 2 %32
    • With the screws removed, you can now remove the motherboard. Using tweezers or just your fingers, pick up the motherboard and place it to the side.
    Pergunte ao FixBot
    Comentar
  11. Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: passo 11, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: passo 11, imagem 2 %32 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: passo 11, imagem 3 %32
    • Using a PH00 screwdriver, remove the 6 highlighted 2mm screws.
    • Pull the ribbon cables away from the back of the display screen. The right cable can be removed completely while the left will stay attached to the front casing.
    Pergunte ao FixBot
    Comentar
  12. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 12, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 12, imagem 2 %32
    • Use the plastic opening tools to pry off the plastic piece at the bottom of the device.
    Pergunte ao FixBot
    Comentar
  13. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 13, imagem 1 %32
    • Pull away the digitizer ribbon cable using the tweezers. It will stay attached to the front casing.
    Pergunte ao FixBot
    Comentar
  14. Alcatel One Touch Pop 7 Display Assembly Replacement: passo 14, imagem 1 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 14, imagem 2 %32 Alcatel One Touch Pop 7 Display Assembly Replacement: passo 14, imagem 3 %32
    • With the screws and ribbon cables removed, the display panel can be separated from the digitizer. You can pull the display panel away from the digitizer or turn it vertically and catch the display panel as it falls out.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Riley Cooper
Membro desde: 10/10/16
926 Reputação
Autoria de 5 guias
Equipe
1Comentário do guia
Hi please I will like to ask weather you have the screen in stock...am from Ghana... kindly hit me back on jamessalia11@gmail.com
Will be glad to hear from you
james salia - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 52
Ao todo: 5,367
