Ir para o conteúdo principal
Alcatel One Touch Pop 7 Microphone Replacement
O que você precisa
  1. Alcatel One Touch Pop 7  Microphone Replacement, Back Cover: passo 1, imagem 1 %32
    • Begin by opening SD port cover as this is the best location to start prying.
  2. Alcatel One Touch Pop 7  Microphone Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  3. Alcatel One Touch Pop 7  Microphone Replacement, Microphone: passo 3, imagem 1 %32
    • Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
  4. Alcatel One Touch Pop 7  Microphone Replacement: passo 4, imagem 1 %32
    • Remove the Microphone from it's slot with the precision tweezers.
  5. Alcatel One Touch Pop 7  Microphone Replacement: passo 5, imagem 1 %32
    • Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers. For information on how to solder safely and correctly go to this link: Como soldar e dessoldar contatos
Conclusão
Philip Schenck
Membro desde: 03/20/18
181 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S6-G2, Baechle Spring 2018 Membro de IUPUI, Team S6-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 832
