Ir para o conteúdo principal
Alcatel One Touch Pop 7 Microphone Replacement
O que você precisa
  1. Alcatel One Touch Pop 7  Microphone Replacement, Back Cover: passo 1, imagem 1 %32
    • Begin by opening SD port cover as this is the best location to start prying.
  2. Alcatel One Touch Pop 7  Microphone Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  3. Alcatel One Touch Pop 7  Microphone Replacement, Microphone: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
  4. Alcatel One Touch Pop 7  Microphone Replacement: passo 4, imagem 1 %32
    • Remove the Microphone from it's slot with the precision tweezers.
  5. Alcatel One Touch Pop 7  Microphone Replacement: passo 5, imagem 1 %32
    • Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers. For information on how to solder safely and correctly go to this link: Como soldar e dessoldar contatos
Conclusão
Uma outra pessoa concluiu este guia.
Philip Schenck
Membro desde: 03/20/18
202 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S6-G2, Baechle Spring 2018 Membro de IUPUI, Team S6-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G2
3 Membros
Autoria de 8 guias
1Comentário do guia
My tablet Alcatel just went off I don't know the problem I tried charging it,it doesn't even show its charging
Siphamandla Mtiti - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 1,104
