Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace the headphone jack. This guide requires soldering.
For more information on how to solder and desolder connections, please visit this guide.
O que você precisa
Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
Lift open case by the corner nearest the divot and remove it from the phone.
Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
Flip the motherboard upside-down and desolder the pin connection of headphone jack to the motherboard.
Once pins desolder, pull the headphone jack out.
