Ir para o conteúdo principal
Alan 48 Excel: Reception problems? No problem!
O que você precisa
    • First of all: Power off! Switch it off and unplug the device.
    • Then grab your screwdriver and undo the screws on the housing.
    • Carefully lift off the housing and put it to one side.
    Pergunte ao FixBot
    Comentar
    • Check all cables and connections. Are they properly seated?
    • Especially important: Check the connections to the antenna and the loudspeaker.
    Pergunte ao FixBot
    Comentar
    • Time for some contact spray and brushes! Spray the connections thoroughly.
    • Wait a few minutes, then wipe away the residue with a clean cloth.
    Pergunte ao FixBot
    Comentar
  1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: passo 4, imagem 1 %32
    • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
    • Take your multimeter and check the transistor. If it is defective, it must be replaced.
    Pergunte ao FixBot
    Comentar
  2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: passo 5, imagem 1 %32
    • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
    • Insert the new transistor and solder it in place.
    • Check the connections with the multimeter to make sure that everything is properly working.
    Pergunte ao FixBot
    Comentar
    • Put the housing back on and tighten the screws.
    • Plug in the plug, switch on the device.
    • Test whether the reception is now better.
    Pergunte ao FixBot
    Comentar
Conclusão
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Ingo Bünnemeyer
Membro desde: 06/06/16
248 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 56
Ao todo: 1,945
