Ir para o conteúdo principal
AirCard 770S SIM Card Replacement
  1. AirCard 770S SIM Card Replacement, SIM Card: passo 1, imagem 1 %32
    • Hold the device with the charging port side facing up.
    Pergunte ao FixBot
    Comentar
  2. AirCard 770S SIM Card Replacement: passo 2, imagem 1 %32
    • Look to the left of the charging port and peel back the SIM Card slot in order to open it.
    Pergunte ao FixBot
    Comentar
  3. AirCard 770S SIM Card Replacement: passo 3, imagem 1 %32
    • If there is already a SIM Card in the slot, use your finger to press in the SIM Card so that it will pop out slightly. If it does not pop out the first time, press it in again.
    • The SIM Card is not shown in picture. The red circle is where the SIM Card would be located.
    Pergunte ao FixBot
    Comentar
  4. AirCard 770S SIM Card Replacement: passo 4, imagem 1 %32
    • Use your fingers and carefully pull out the old SIM Card.
    • The SIM Card is not included in picture. The orange circle is where SIM Card would be located on the device.
    • When reassembling the device, make sure to press in the new SIM Card all the way so that the port can be closed and you can then power on the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Caitlin Little
Membro desde: 10/08/18
437 Reputação
Autoria de 3 guias
Equipe
Marist, Team S1-G2, Chaterdon Fall 2018 Membro de Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Ao todo: 2,287
