Ir para o conteúdo principal
AirCard 770S Battery Replacement
O que você precisa
  1. AirCard 770S Battery Replacement, Battery: passo 1, imagem 1 %32
    • Hold the device with an open corner available and facing you.
    Pergunte ao FixBot
    Comentar
  2. AirCard 770S Battery Replacement: passo 2, imagem 1 %32
    • Using your finger, pry open any of the four corners of the back of your AirCard 770S, until you see the back case disconnect from the device.
    Pergunte ao FixBot
    Comentar
  3. AirCard 770S Battery Replacement: passo 3, imagem 1 %32
    • Lift open the back case and remove it from the device.
    Pergunte ao FixBot
    Comentar
  4. AirCard 770S Battery Replacement: passo 4, imagem 1 %32
    • With the bottom of the device (above the charging port) facing you, use your thumb nail to lift up the battery.
    Pergunte ao FixBot
    Comentar
  5. AirCard 770S Battery Replacement: passo 5, imagem 1 %32
    • Once the battery is lifted up, use the rest of your hand to remove the battery out from the device.
    • To put the battery back in to the device, make sure to align the "gold stripes" on the side of the battery to where they correspond in the base of the device, and align the backing to reassemble to device.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Caitlin Little
Membro desde: 10/08/18
437 Reputação
Autoria de 3 guias
Equipe
Marist, Team S1-G2, Chaterdon Fall 2018 Membro de Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 1,588
