Ir para o conteúdo principal
Air Hog Smash Bots Radio Receiver Replacement
O que você precisa
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: passo 1, imagem 1 %32
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: passo 2, imagem 1 %32
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: passo 3, imagem 1 %32
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: passo 4, imagem 1 %32 Air Hog Smash Bots Radio Receiver Replacement, External Casing: passo 4, imagem 2 %32
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: passo 5, imagem 1 %32 Air Hog Smash Bots Radio Receiver Replacement: passo 5, imagem 2 %32
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: passo 6, imagem 1 %32
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: passo 7, imagem 1 %32
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: passo 8, imagem 1 %32 Air Hog Smash Bots Radio Receiver Replacement: passo 8, imagem 2 %32
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: passo 9, imagem 1 %32 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: passo 9, imagem 2 %32
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: passo 10, imagem 1 %32 Air Hog Smash Bots Radio Receiver Replacement: passo 10, imagem 2 %32
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Conclusão
Uma outra pessoa concluiu este guia.
Brittany Frecker
Membro desde: 02/08/16
542 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-1, Baechle Spring 2016 Membro de IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 266
