Ir para o conteúdo principal
Air Filter Replacement
  1. Air Filter Replacement, Filter: passo 1, imagem 1 %32
    • Locate air filter grille
    • This is usually found near the thermostat
    • Some systems contain multiple filters
    • Not all duct systems have a filter grill. Some are filtered at the air handling appliance
    Pergunte ao FixBot
    Comentar
  2. Air Filter Replacement, Open the grill: passo 2, imagem 1 %32 Air Filter Replacement, Open the grill: passo 2, imagem 2 %32
    • Pull out both latches so that they are perpendicular to the wall
    • Pull grill open from top center
    Pergunte ao FixBot
    Comentar
  3. Air Filter Replacement, Remove used filter: passo 3, imagem 1 %32
    • Remove the dirty filter
    Pergunte ao FixBot
    Comentar
    • If you aren't sure if the filter is ready to be changed just remember this is what cleans the air you are breathing.
    • Never wash or reuse a disposable filter
    • Pleated filters remove more dirt from the air than fiberglass filters. But their density restricts the air flow more. This can create problems in some systems. Experiment with both and see which is best for you and your system.
    • Filters should be checked every 30 days on residential applications and every 15 days on commercial applications.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
gsdfert34f2efse34
Membro desde: 08/06/15
43 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 582
