Ir para o conteúdo principal
Afterglow Wireless PS3 Controller Vibration Motor Replacement
O que você precisa
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: passo 1, imagem 1 %32 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: passo 1, imagem 2 %32
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: passo 2, imagem 1 %32 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: passo 2, imagem 2 %32
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 3, imagem 1 %32
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 4, imagem 1 %32 Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 4, imagem 2 %32 Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 4, imagem 3 %32
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 5, imagem 1 %32 Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 5, imagem 2 %32
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: passo 6, imagem 1 %32
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
Conclusão
Natalie Cox
Membro desde: 02/17/17
207 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 1,215
